На сайте: гостей - 28,
 LPD-Форум —› LPD, FRS, PMR - радиосвязь без лицензий —› Пакет на 27235
RadioKoteg
Дата: 20 Июн 2010 16:59:55 #
Здравствуйте!
Угораздило меня попасть на 27235, не долго думая достал программу терминала для Packet AX25, с моими знаниями англо немецкого и еще какогото языка вот результат:
*** TRYING DGR277...
*** CONNECTED.
_ _ _ __ __ __
/ / /__ /__/ __/ / /
/__/ /__/ / /__ / / JO43XO Hamburg-Eppendorf
Hallo RS147, please send name like this: //N Fiete Hamburg JO43XO,
ich grЃбe Dich von der Waterkant und ich hoffe dass es Dir gut geht.
22:39 RS147>DGR277>SABM,P
Hallo Danil, wo steckst Du denn ?
Oh, Ukraine, a long Distance.
1st qth: 30 12' 30" East 50 13' 45" North --> KO50CF = PK62h
2nd qth: 9 57' 30" East 53 36' 15" North --> JO43XO = EN40b
distance: 1433.0 km
course 1 --> 2: 293 (West-North-West)
course 2 --> 1: 97 (East)
Buchtipp: Die unsichtbare Hand von A. Ralph Epperson
english titel: the unseen hand
an other good book: The Schockdoctrine by Naomi Klein.
german titel: Die Schockstrategie
Here are some informations about DGR277
Nickname : Fiete
TX/RX : Abrecht AE 8000 with an integrated PC-COM-modem 26,565 - 27,405
TX-power : ;)
RX-controller: DNT CB-Funk-Observer ( S-meter-program with modem for Windows )
1.PC and 2.PC: 1.Fujitsu Pentium 3/450 MHz 2.Siemens-Fujitsu Pentium 3/600 MHz
Antenna : Solarcon I-Max 2000 with 4 radials ( built 2005 ) on the roof
PR-program : Graphic Packet version 1.63 for MS-DOS 7.10 mobilcall:D1G277
QTH : Hamburg-Eppendorf JO43XO. The top of the south of Scandinavia ;) GP-Chatnode : First send //cs for connect-status and you will see who is on
which channel, send //1 or //2 aso. and after this send //E //2
or //E //1 aso. and after this you are connected.
The book for you: The Shock Doctrine from Naomi Klein by Metropolitan Books NY
I have also seen UU51 and UT5xxx on my screen this night. 20.06.2010
Greetings from Hamburg to them.
tnx
my call RS147
Yes i`ve seen and noticed it.
But how is your real Locator ? Do you know that ?
KO50FK
Kiev
Capital of Uraine
1st qth: 30 27' 30" East 50 26' 15" North --> KO50FK = PK43g
distance: 1440.5 km
course 1 --> 2: 292 (West-North-West)
course 2 --> 1: 96 (East)
1440,5 Kilometer is the right distance then.
How much packeteers/packet-radio-user are in Kiev and in your country ?
HELP
UKRAINE
OK, i will try. How i am able to help you ?
im novice
OK, i understand. I was beginning in the year 2005, and i am glad about.
//QTH Hamburg
//LOC JO43XO
no? im in packet novice.
Yes, i understand.
ок
i was that 5 years ago.
you human?
Yes i am a real german man, born in 1957 in Hamburg.
sorry
good night to you
im bad speak english
Yes, i know it yet. My name is Fiete. :) a typical name in North-Germany.
very good!
That des' nt metter, because you will train it with packet radio.
It is my first connect to Kiev and the Ukraine.
ok!
Some years ago i had connects to russian stations.
im primary connect packet ax25
You can find packet-radio-stations in all europeen countrys nearly.
And at once such a long distance. My gratulations.
I do not use telephone or I-Net. Only packet-radio.
If you have a telefon here, it is ringing the hole day.
Thank you for the information
<GP>: MH-Liste Stationen: 20/612 (20.06.2010; 01:12:19 MESZ)
20.06.2010 01:11 RS147 > DGR277
20.06.2010 01:11 DGR277 > RS147
20.06.2010 01:00 DGR277 > EUROPE
20.06.2010 00:32 RS147 > WO6NOD
19.06.2010 00:28 DGR277 > UU5
20.06.2010 00:28 UU51 > DNX501
19.06.2010 00:28 DGR277 > UT5Uxx
20.06.2010 00:27 UT5UBX > DNX501
20.06.2010 00:24 UU5 > QST
19.06.2010 21:36 HEM201 > MA4NOD via HEM254*
19.06.2010 21:07 MA4NOD > DNO3TR
19.06.2010 21:02 DL0JK > HED228 via MA4NOD*
19.06.2010 20:39 HED228 > MA4NOD
19.06.2010 20:15 HED228 > CQ
19.06.2010 19:45 HEF235 > DRS800
19.06.2010 19:45 HEJ781 > PER1UM via HEF235*
19.06.2010 18:58 DGR277 > DRS800-15
19.06.2010 18:57 DGR277 > RSTNOD
19.06.2010 18:56 DGR277-2 > RSTNOD
19.06.2010 18:51 DRS800-15 > DGR277
So, i will finisch now. I wish you a lot of fine connections.
01:14:46 20.06.2010 bye RS147 from DGR277
< > 55 , 73 and until next qso
//Q
list
BBS ?
<GP>: Remote-Hilfe:
//<n> <Text> : Text an Kanal <n> senden
//7+ <ON/OFF> : Schaltet 7+ AutoSave an oder aus
//Activity : Sysop-Aktivitaet abfragen
//Bell : Sysop rufen
//CATalog [Filter] : Liste der Dateien, die gelesen werden koennen
//CD <Verzeichnis> : Wechselt in ein anderes User-Verzeichnis
//CUT : Bricht einen Lesevorgang ab
//DELete : Loescht eine mit //Write angelegte Datei
//DIRectory [Filter] : siehe //CATalog
//DISConnect : Schneller Disconnect (ohne Verabschiedung)
//Echo <text> : Sendet "text" zurueck
//END : Beendet eine mit //Write gestartete Textspeicherung
//Help [befehl] : Diese Meldung bzw. detaillierte Hilfe fuer "befehl"
//Info : Sendet die Stationsinfo (wenn vorhanden)
//Language <sprache> : Wechselt die Sprache der Meldungen
//MHeard [anzahl] : Zeigt eine Liste von gehoerten Stationen
//MHeard <call> : Gibt aus, in wann <call> zuletzt gehoert wurde
//Name <name> : Speicherung des eigenen Namens in die Namensdatei
//NEws : Aktuelle Neuigkeiten (wenn vorhanden)
//PARameters : Zeigt die Einstellungen einiger TNC-Parameter an
//PRompt <ON/OFF> : Schaltet das Prompt an oder aus
//Quit : Beendet die Verbindung
//Read <datei> : Sendet die Datei "datei"
//RPrg <datei> : Sendet eine Binaerdatei im Automodus
//RTt <PortNr> : Laufzeitmessung der Verbindung
//RUN <programm> : Startet ein externes Programm
//Usage [rufzeichen] : Liste der connecteten Stationen
//VERsion : Zeigt die Versionsnummer dieser Software
//Write <datei> : Speichert den folgenden Text in die Datei "datei"
//WPrg <datei> : Speichert eine Binaerdatei im Automodus
Alle Befehle muessen am Anfang der Zeile beginnen und mit <CR> beendet
werden.
Weiteres mit //Help Help
No BBS no Node
tnx
My Home-BBS is HEE222 in Lugano -Swiss ( Schweiz )
TNX
73
bye bye and until next time again.
until next QSO
BYE
/Q
*** РАЗЪЕДИНИЛИСЬ С... DGR277: Normal.
Connection statistics:
Frames sent/rcvd: 192/159, Bytes sent/rcvd:389/6029, REJs sent/rcvd: 8/3, T1 timeouts: 14
RadioKoteg
Дата: 20 Июн 2010 17:02:44 #
С этого всего возникли вопросы:
1. Что за сеть и ее назначение?
2. Как в ней работать, я привык BBS , файл архивы а также почта, а тут непонятно, или я попался на просто оператора.
В общем знающие растолкуйте чайнику.
askaev
Каменск-Шахтинский
Дата: 21 Июн 2010 00:15:47 #
Дионис напоминает, но не он.
Spetznaz
Offline4.1
United Kingdom
Дата: 21 Июн 2010 01:22:02 #
agents
Нижний Новгород 50RS014
Дата: 21 Июн 2010 12:02:28 · Поправил: agents (21 Июн 2010 12:03:51) #
RadioKoteg
Я этим давно уже занимаюсь,жаль пока напарников в городе нет хотя раньше были да вот все разбежались с радио в инет.
Пакет на СБ это смесь интернет и BBS фидо в 90е годы.В Европе это неплохо развито а в СНГ почему то не пошло так сильно.
http://www-2.dyndns.org/
http://fra278.free.fr/pages/9.html
Вот некоторые точки входа в пакетную сеть с интернет.
Будут вопросы,задавай
http://www.uic.unn.ru/~kaas9/ вот это когда то у нас в городе на СБ было развито ща я остался один,надо поднимать опять узел пока не забыл что и как :)
http://goryham.qrz.ru/pr/index.html тут почитай,там очень всё хорошо написано про это.
agents
Дата: 27 Май 2012 16:56:41 · Поправил: agents (27 Май 2012 17:00:31) #
Ну шо,тема ушла в низ.Поднимем тему и тему ПАКЕТа на СБ.Если кто желает подключайте рации к компьютеру и вперёд на 27235ЧМ!
Кстати есть идея сделать единую частоту не в основной сетке частот для пакетной связи или АПРС что бы не мешать пиликанием простых пользователей.
RadioKoteg
Дата: 14 Июн 2015 23:35:04 · Поправил: RadioKoteg (14 Июн 2015 23:41:04) #
Есть замечательный программный модем и терминал к ему http://uz7.ho.ua/packetradio.htm
Модем для пакетной связи под звуковую плату
Soundmodem - проект, представляющий собой программный модем для пакетной связи под звуковую плату. Модем работает по протоколу AX.25, в одноканальном и двухканальном (стерео) режиме, и поддерживает скорости, для AFSK модуляци: 300, 600, 1200 и 2400, для FSK (G3RUH): 9600 и 19200 бод. Для связи с программным обеспечением, модем использует AGW Packet Engine API протокол, работающий по TCP/IP и эмулирующий режим AGW PE. Модем успешно протестирован под Windows 98, XP, Vista, W7 и W8 с такими программами как: F6FBB, Paxon, WPP, AGWTerm, BPQ32. Он также подходит для работы в сетях APRS: UI-View32/16, UISS и др.
сам модем http://uz7.ho.ua/modem_beta/soundmodem83.zip
терминал http://uz7.ho.ua/modem_beta/EasyTerm32.zip
RK6AJE
Оттуда
Дата: 15 Июн 2015 08:42:06 · Поправил: RK6AJE (15 Июн 2015 08:45:26) #
Добрэ!
Я вам хочу сказать, что большая часть слушателей/пользователей Си-Би не знает, что такое пакет. И, заслышав непонятное "шкварчание" начинают материться и учинять помехи на частоте. Иногда местным мешают. Тут давече в ROS на 27245 работал в USB - так обматерили, окаянные, не поняли, что пиликают совсем не про их душу и чаяния... :-)
В результате, ROS перенесли на за 27.500, от обычных юзверей подальше. Что можно ловить в ЧМ-пакете в основной сетке, когда по прохождению сигнал 8-9 баллов, а шкварчит на 7-9 - хоть убей не понимаю. Думаю, за 27.500 надо тоже оттягивать.
Zmej
Дата: 20 Июн 2015 13:30:00 #
А еще лучше на 29250. У большинства есть и нормальные позывные.
agents
Дата: 28 Июн 2015 16:21:02 #
Пакет так и пилит на 27.235 чм.
На 27.700 вроде сств проскакивает периодически.
