На сайте: гостей - 30,
 LPD-Форум —› CB - гражданская радиосвязь —› Cobra 19 DX IV
aat
с окт 2007
Дата: 23 Ноя 2007 12:01:07 #
Уважаемые,
Кто что может сказать на счет данной рации? Очень интересует Ваше мнение. Может кто юзает ее? Стоит ее покупать или нет?
Заранее благодарен
Top Secret
с ноя 2006
Дата: 23 Ноя 2007 12:10:39 #
aat
Переведите это и всё станет ясно ))
* Good Product. It s a Cobra what more can be said. It does everthing it is supposed to and does it well
* Small radio with lots of annoyances.. I bought the Cobra 19 DX IV for my wife s car since we needed a small radio without bells and whistles.
This radio appeared to be a perfect fit for my needs. But, after using it, I am disappointed with this radio. Here s why:
1. Unit resets to channel 01 when it loses power. So either wire it directly to the battery (and remember to turn it off!) or wire it to accessory power and work channel 01 every time you start the car.
2. Poppy squelch. When a weak signal breaks the squelch then fades, the squelch makes an annoying popping sound as it squelches the audio.
3. S/RF meter shows nothing (drops to zero) when squelch activates. If the squelch is set fairly high, the meter shows no signal until someone manages to break the squelch. I personally think the meter should show all RF activity whether the squelch is on or off.
Hope this helps someone.
* what do you expect. for the price, its a good little radio... if you want more extras you are going to have to shell out more bucksthe lcd screen works fine....
* good value. cb is an excellent value,it worked fine and has an adjustable rf gain.
* BAD DISPLAY. This radio has good receiption, but display screen sucks, bright on both ends of display but dark in the middle,i sent it back to Cobra for this problem and they returned it saying their was nothing wrong with the display screen, can t beleive Cobra thinks the display looks ok.
Hixx
Волгоград
Дата: 23 Ноя 2007 12:36:35 #
Poppy squelch.
"Poppy" = "мак".
Маковый шумоподавитель, который через раз спрашивает: "Ааа??"..
Потом, наверное Ganja RF-filter, Coca-amplifier ))
Плохой дисплей. Радио принимает нормально, а вот дисплей отсасывает ))
Хорошая статейка. После перевода - вообще зашибись!
Top Secret
с ноя 2006
Дата: 23 Ноя 2007 12:48:13 #
Hixx
А у них в области CВ сплошные жаргонизмы, которые нам малопонятны.
Эта моделька для "правильного" американского дальнобойщика. Мордашка у неё достаточно симпотная, жаль только, что голая АМ.
Hixx
Волгоград
Дата: 23 Ноя 2007 13:31:51 #
Top Secret
Ну в области жаргонизмов есть некоторая подкованность.
Poppy - хлопающий, мечущийся.. Короче, шумодав без гистерезиса )))
aat
с окт 2007
Дата: 23 Ноя 2007 22:23:06 #
А если попробовать сравнить Cobra 19 DX IV или President Harry II ASC, что предпочтительнее взять? (http://www.president24.pl/product-pol-1852360-Harry-II-ASC.html)
nostromo
с июн 2007
Азербайджан
Дата: 23 Ноя 2007 23:00:56 #
aat
Лучше сразу возьми это : http://www.president.com.pl/img/product/big/cb-radia/cb_johnson_ii_asc.jpg
Хотя и Харик вообщем то не плох.
aat
с окт 2007
Дата: 24 Ноя 2007 01:14:32 #
А чем она лучше?
nostromo
с июн 2007
Азербайджан
Дата: 24 Ноя 2007 16:10:45 #
Чем лучше Лексус Опеля? Примерно так же. 8-)
aat
с окт 2007
Дата: 25 Ноя 2007 03:13:17 #
Ой незнаю......
Хочется маленькую, а Джонсон большой.....
Просто большую ставить проблемотично, вот и сомневаюсь
nostromo
с июн 2007
Азербайджан
Дата: 25 Ноя 2007 12:25:47 #
Сам аппарат в глубину меньше чем Харик,но шире и выше.Идеально встаёт в однодиновое отверстие под автомагнитолу.Да и динамик на передней панели даёт массу преймуществ.У меня многие её устанавливают именно в легковухи.Недавно получил электронные брошюры на новые модели Интеков,у которых динамики тоже стоят на передней панели.Это Intek M-150 Plus и Intek M-760 Plus.Трудно сказать как они будут по надёжности,но модельный ряд этой фирмы как то уж очень бурно расширяется.Масса наваротов у этих аппаратов конечно подкупят многих.
aat
с окт 2007
Дата: 25 Ноя 2007 12:59:23 #
Ой а что, Stabo XM 5003 и President Johnson II это одно и тоже? Или просто внешни похожи?
nostromo
с июн 2007
Азербайджан
Дата: 25 Ноя 2007 14:59:57 #
Наверно одно и то же.Тока производитель разный.А может и нет.Фиг поймёшь эти маркетинговые ходы.
Sereban
с фев 2015
Екатеринбург
Дата: 19 Фев 2015 09:32:33 #
Здраствуйте! может кто нибудь подсказать как настроить данный аппарат?
Заезжал в магазин, они подключали к ней устройство. говорят что все впорядке. А на самом деле: ставлю 15 канал, АМ ииии....ничего..., никого не слышу, и не знаю слышит ли меня кто-то.
Хотелось пользоваться на трассе, попасть в канал к дальнобойщикам.
Nastra
с дек 2012
Дата: 19 Фев 2015 09:35:28 #
Возможно, что сетка не та.
27.135 - нужная частота.
Возможно, что-то с антенной.
Sereban
с фев 2015
Екатеринбург
Дата: 19 Фев 2015 09:43:12 #
Nastra
Долго удерживая кнопку переключения АМ/FM, попадаю на на выбор чего то) сам не знаю чего, Можно выбрать a, b, c, d, e, f
Пробовал на всех.
А что это за настройки?
Alarm
с фев 2013
GPS-off
Дата: 19 Фев 2015 09:48:57 #
Sereban
a, b, c, d, e, f
Это разные сетки частот (диапазоны). У нас используется сетка С
Sereban
с фев 2015
Екатеринбург
Дата: 19 Фев 2015 11:11:24 #
Всем спасибо! Пойду пробовать.
ru9tr
Дата: 20 Апр 2015 22:12:23 #
Если Кобра азиатская (с автошумодавом и ESP) то сетка d должна быть.
