На сайте: гостей - 31,
 LPD-Форум —› CB - гражданская радиосвязь —› Intek H-520 - никто не сталкивался?
 Страница:  1  2  3  4  5  6  »»Поиск в теме
flip
Казахстан, Алматы, UN9GIR
Дата: 06 Янв 2009 15:30:06 · Поправил: flip #
Интересует САБЖ
Вроде прикольный аппарат (с виду) А как оно в работе? Например по сравнению с Алан 42?
flip
Дата: 06 Янв 2009 15:31:01 #
Описание - даже вроде есть российская сетка
World's most advanced Citizen Band (CB 27 MHz) handheld transceiver, with 8-band programmable multi standard circuit design, matching the frequency & operating mode requirements of various countries. A number of unique features makes this radio the most advanced and sofisticated portable CB transceiver ever developed. Just to name a few, the extra large 1.8"/5-line LCD display, the "2nd generation" ESP (Electronic Speech Processor), the low voltage/low current drain MOSFET transmitter circuit design and much more. One radio only, ready for use in all the European countries !
Main features :
8 BAND PROGRAMMABLE MULTI STANDARD TECHNOLOGY
EXTRA LARGE 5-LINES 1.8" BACKLIGHTED LCD DISPLAY, THE LARGEST LCD DISPLAY EVER IN A CB HANDHELD RADIO
LCD SIMULTANEOUSLY SHOWS CHANNEL, BAND ID CODE, 5-DIGIT FREQUENCY, AM/FM MODE, TX POWER, MEMORY AND EVERY OTHER ENABLED FUNCTION,
3-FUNCTION DIGITAL BAR METER (RX SIGNAL, TX RF POWER, MODULATION)
ADVANCED LOW CURRENT DRAIN MOSFET TRANSMITTER CIRCUIT DESIGN
2nd GENERATION ESP COMPANDER (RX/TX AUDIO SPEECH PROCESSOR), TX COMPRESSOR AND RX EXPANDER MAY BE OPERATED SEPARATELY
8 MEMORY CHANNELS
3-LEVEL SELECTABLE TRANSMITTER RF OUTPUT POWER (100mW, 1W, 4W)
DUAL WATCH, CHANNEL/MEMORY CHANNEL SCAN, EMG, LCR, LOCK, LCD BACKLIGHT, QUICK UP AND QUICK DOWN CHANNEL SELECTION
MANUAL SQUELCH CONTROL OR FIXED SQUELCH (AS) FUNCTION
BATTERY 4-LEVEL INDICATOR
ONLY 6 X AA RECHARGEABLE OR ALKALINE BATTERIES ARE REQUIRED
STANDARD 2-PIN EXTERNAL EARSET-MICROPHONE JACK
CAR ADAPTOR FOR MOBILE USE (MAY BE OPTIONAL DEPENDING ON THE PACKAGE)
230VAC TRAVEL CHARGER (MAY BE OPTIONAL DEPENDING ON THE PACKAGE)
CONTACTS FOR CAR ADAPTOR AND FOR DESK TYPE RAPID CHARGER
SPECIFICATIONS
GENERAL
Channels: Refer to programmed band
Modes: (AM/FM) Refer to programmed band
Operating Temp.: -10°/+55°C
DC Input Voltage: 7.2-9.0Vdc ±15%
Size: 68(L) x146(H) x 38(D) mm
Weight: 218 gr. (w/out batt. and ant.)
RECEIVER
System: Double Conv. Super Heter.
IF: 1° 10.695 MHz / 2° 455 KHz
Sensitivity: 0.5V for 20dB SINAD (FM) 0.7V for 20dB SINAD (AM)
Audio Output Power: 0.3W at 8 Ohm
Audio Distorsion: <8% at 1 KHz
Signal/Noise Ratio: 45dB
TRANSMITTER
System: CPU Controlled PLL Synth.
Max Output Power: 4W at 9.0Vdc
Modulation: AM / FM
Output Impedance: 50 Ohm unbalanced
Current Drain: 1500 mA (at no modulation)
H-520 Plus
FREQUENCY BAND / MODE PROGRAM
E1 ITALY/SPAIN 40CH AM/FM 4W
I2 ITALY 36CH AM / FM 4W
DE GERMANY 80CH FM 4W / 12CH AM 1W
D2 GERMANY 40CH FM 4W / 12CH AM 1W
EU EUROPE/FRANCE
40CH FM 4W / 40CH AM 1W
CE CEPT 40CH FM 4W (DEFAULT)
UK ENGLAND 40CH + CEPT 40CH FM 4W
PL POLAND 40CH AM/FM 4W (-5 KHz)
nostromo
с июн 2007
Азербайджан
Дата: 06 Янв 2009 20:49:48 #
Н-520 нормальный аппаратик.Я с ними уже давненько работаю.Есть конечно ньюансы.А нормальная аппаратура Аланом называться не может(народная мудрость). :-))))) Так что тут и сравнивать нечего.
Чья то тень
с окт 2008
Дата: 06 Янв 2009 21:52:57 #
нормальные интеки ?
flip
Дата: 07 Янв 2009 07:45:09 #
Из доступных поративок пока нашел только эти, Аланы 42 и еще что-то непонятное китайское... Так что выбор невелик.
nostromo
Отписал в личку
RN0QQ
с мая 2008
оттуда...
Дата: 10 Мар 2009 18:15:29 #
Интересный аппарат.. А где купить можно?
DeepM
Offline4.3
Москва Вешняки
Дата: 17 Апр 2009 10:28:24 #
Куплю аппаратик - пишите в личку.
Арти
с апр 2009
Петрозаводск
Дата: 17 Апр 2009 14:01:00 #
Дак где в россии купить можно такой аппарат?? И стоймость?
По поводу аппарата, прочитал описание присланное уважаемым nostromo, аппарат понравился, алан 42 "нервно курит в сторонке". Вопрос как достать
nostromo
с июн 2007
Азербайджан
Дата: 17 Апр 2009 18:46:56 #
Арти
ну щас гении вопли поднимут.Забавно поглядеть..............
Арти
с апр 2009
Петрозаводск
Дата: 17 Апр 2009 19:05:03 #
Арти
А на форуме ci-bi наоборот медаль сразу дадут ;-))))
nostromo
с июн 2007
Азербайджан
Дата: 17 Апр 2009 20:10:07 #
наша почта за доставку возьмёт порядка 10 евреев.По сравнению с америкосами или европой-цена смехотворная.
Арти
с апр 2009
Петрозаводск
Дата: 17 Апр 2009 20:30:18 #
А в рублях не сложно написать цену р/ст и стоимость доставки. А то я курс лат к рубликам не нашел. Ну и условия оплаты.
Лучше в личку.
Привет городу Алуксне где я вырос
nostromo
с июн 2007
Азербайджан
Дата: 17 Апр 2009 21:16:58 · Поправил: nostromo #
:-)))))) ок !!! Это в корне меняет дело !!!
Лучше в личку.
эт точно.
Арти
с апр 2009
Петрозаводск
Дата: 19 Апр 2009 09:45:58 #
Тут с утра посетила мысль, а удастся ли зарегистрировать данную р/ст в российском РЧЦентре???
Для тех же самых Аланов 42 и Майкомов 27 есть российский сертификат соответствия, а для Интека Н520 нигде инфы нет. Обломно будет купить а ее откажутся регистрировать
Арти
с апр 2009
Петрозаводск
Дата: 19 Апр 2009 09:52:37 #
Еще вопрос интересен, как переключается мощность передатчика? И зависит ли мощность передатчика от напряжения питания 7.2В/9В/12В? Есть подозрение что в зависимости от номинала питания мощность будет соответствовать 0.1Вт/ 1.0Вт/4Вт
Шариков
Offline2.8
с фев 2006
Пречистенка
Дата: 19 Апр 2009 10:54:58 #
Мощность, естественно, зависит. Но не так. От 7,2в будет в районе 2 Вт на максимуме.
Рация не плохая, но подумайте - стоит ли 100 долларов за геморой с гарантией, с регистрацией и с покупкой? Всё, чего вы получите за эти деньги - ESP.
Эта рация разрабатывалась изначально как Alan 52+ , но Алан отказался по коньюктурным соображениям (и не прогадал, Алан42+ в Европе продается на порядок больше)
Дальности связи, большей чем у 42+ или Майком, от неё не получите.
Арти
с апр 2009
Петрозаводск
Дата: 19 Апр 2009 11:02:54 #
Шариков
Вот и я в раздумьях
starik2000
Брест
Дата: 18 Мар 2010 19:48:07 · Поправил: starik2000 (18 Мар 2010 19:53:18) #
подниму тему . Нужна переноска - реально есть выбор - причем узкий Либо интек 520 либо 42алан. обе стоят около 100 в наших краях . Но с продукцией интека пересекался только с микрофонами - качество мне совершенно не понравилось.
+Интека
Большой дисплей
Не Алан
+ Алана
отстегивается отсек батареек
Легче продать в силу раскрученности имени
В работе алан 42 был - интек нет , вот и мучаюсь. Если они в работе одинаковы - то смысла в интеке мне нет. В работе = качество модуляции / удобства переноски из машины в машину/ Набор функций не интересен
Михаил Л
с июн 2006
Дата: 19 Мар 2010 15:35:21 #
Тоже смотрю в его сторону! В разных форумах задавал вопрос про авто шумодав. Вроде анонсируют, что эта единственная СВ переноска со спектральным шумодавом. А вот как реально он работает никто пока не отписался! :-((
Сейчас использую в машине Maycom SH27 - шумодав приходится крутить постоянно, и это не очень удобно.
ИМХО еще + Интека: одновременное отображение частоты и канала
starik2000
Брест
Дата: 19 Мар 2010 17:12:50 · Поправил: starik2000 (19 Мар 2010 17:13:10) #
Михаил Л
Ну это плюс кому как. Мне вообще на 99% нужен 15 +19 АМ канал :)
бобр
с фев 2010
Дата: 19 Мар 2010 18:10:55 #
starik2000, привези Интек, я куплю, раскурочу и все про него расскажу.
addressed
с мар 2008
Дата: 20 Мар 2010 22:33:35 #
Из CB переносок самая современная, в РФ зарегистрируете без особых проблем.
Шариков
Offline2.8
с фев 2006
Пречистенка
Дата: 21 Мар 2010 08:53:42 #
Дружок, откуда дровишки? В руках лично держал? Сам регистрировал? 512-й Интек трогал? А Максоновский оригинал? Ещё один горячий сетевой писатель.
Смотрите в схему, Михаил Л. И если сумеете отличить спектральный ШП от уровневого, а автоматический от фиксированного, то всё встанет на свои места.
Михаил Л
с июн 2006
Дата: 21 Мар 2010 11:37:19 #
Блин! А можно без скепсиса и сказать: зарегистрируют или не зарегистрируют потому то и потому то!!!!
Да говорю сразу - НЕ СУМЕЮ!!! А вот Вы, если разбираетесь в этом - расскажите!! Поэтому и спрашиваю!
А то толькот пальцы гнем.
Шариков
Offline2.8
с фев 2006
Пречистенка
Дата: 21 Мар 2010 11:50:22 · Поправил: Шариков (21 Мар 2010 11:54:02) #
Шумодав, если верить схеме УРОВНЕВЫЙ (не спектральный). НЕ АВТОМАТИЧЕСКИЙ (реклама врет). Просто сделан переключатель между ручным и фиксированным - вот и вся автоматика.
Что касается регистрации, то есть сомнения. Если кто-то зарегистрировал без инструментального контроля, то пусть расскажет и покажет.
То, что сервиса в России на эту рацию нет, 100%.
Михаил Л
с июн 2006
Дата: 21 Мар 2010 12:25:52 #
Шариков
Вот за эти разъяснения спасибо!!!
Да, жаль! Значить олять на все посторонние помехи будет открываться.
Михаил Л
с июн 2006
Дата: 23 Мар 2010 16:22:56 #
addressed
О! Наконец-то есть реальный пользователь!!!
А можете по моим вопросам ответить:
или там действительно:
И стоит-ли менять Maycom SH27 на 520-ю?? Реально у 520-й лучше чувствительность, качество приема, разборчивость корреспондентов. В майкоме у меня с этим откровенно не очень!
starik2000
Брест
Дата: 23 Мар 2010 16:55:06 #
Михаил Л Подождите немного :) По договоренности с бобр, я ему сей аппарат на днях отправлю
а он
Так , что думаю через недельку будет полная информация. Алан 42 у него найдется, думаю сравнение будет интересным.
бобр
с фев 2010
Дата: 23 Мар 2010 17:12:02 #
42-й у меня есть, правда старый, не "мульти".
Михаил Л
с июн 2006
Дата: 23 Мар 2010 17:17:04 #
бобр
Могу еще и свой Maycom SH27 подогнать для тестов! :-))
Время загрузки страницы (сек.): 0.022; miniBB®
