На сайте: гостей - 23,
участников - 1 [ Fenix747]
 LPD-Форум —› CB - гражданская радиосвязь —› TTI TCB R2000
peterb
с окт 2013
Bratislava
Дата: 16 Окт 2013 17:00:03 #
ok.. but still I am not getting there.. I connect the radio, turn it up to programming mode, then I fill-in P0-P9 channels.. What do I choose from Band Select in programming software? I have Base Band selected.. Then I click Power Select and change to 12W and I click UPLOAD.
It uploads the config and when I turn the radio on, nothing changes. No special channels..
Зверюга2675
с июл 2010
Дата: 16 Окт 2013 19:36:43 #
After you connect radio to programming mode, click "Program -> read from radio". Then fill-in P0-P9 channels, Power Select change to 12W, Band Select - to OPTYM BAND, P Key - -5 kHz (last position). Then, click "Program -> Write to radio".
I have always done so, and other options have not tried.
peterb
с окт 2013
Bratislava
Дата: 16 Окт 2013 22:35:38 #
I did it and still nothing.. :( Do I have to select specific Band in the radio before I program it? I have EU, EC, E, F, PL, UK, UE, I, I2, D, D2..
After programming I just turn on the radio and I should see the P0-P9 channels after the last channel 40/80?
Зверюга2675
с июл 2010
Дата: 17 Окт 2013 12:10:44 #
Yes!
peterb
с окт 2013
Bratislava
Дата: 18 Окт 2013 00:05:22 #
well.. I do exactly what you say and nothing..
Зверюга2675
с июл 2010
Дата: 18 Окт 2013 08:18:40 · Поправил: Зверюга2675 (18 Окт 2013 08:58:33) #
peterb
I now have three radios TTI TCB-R2000 purchased in Poland. The other day to try their program, and the results accomplish your goal.
Время загрузки страницы (сек.): 0.013; miniBB®
