На сайте: гостей - 24,
участников - 2 [ Stumbler, R1AIT]
 LPD-Форум —› Прочее —› Baofeng DM-5R
 Страница:  1  2  3  4  5  ...  27  28  29  30  31  »»Поиск в теме
GIBBON
Минск
Дата: 18 Сен 2016 22:28:16 · Поправил: GIBBON (18 Сен 2016 22:33:05) #
Кто-нибудь уже держал в руках или стал "счастливым" заказчиком сего нового чуда китайской инженерии?
Baofeng DM-5R DMR Dual Band DigitalRadio
VHF/UHF 136-174/400-480Mhz
2000mAH High Capacity Battery
High Power/Low power
21Cm Dual Band Antenna
8-Level Stepped Frequency Selection
Auto power saving function,Super-Long Standby
Compatibility Of Digital And Analog Under DMR System
Supports Individual Call, Group Call And All Call
Support DMR repeater function (DMR Tier 1)
Pre-sale: Be one of the first to get your hands on BAOFENG’s first DMR, available 9/26! Share our Facebook Post of DM-5R and Send us an email (support@radioddity.com) or Private Message us on Facebook BEFORE 9/26 to claim your BAOFENG DM-5R, and we’ll email you back a coupon for 10% off!
Price: US $69.99 per one
http://qrznow.com/baofeng-dm-5r-dual-band-dmr-digital-radio-new/
Видео по теме:
Package:
1 x DM-5R DMR Two-Way Radio
1 x Antenna
1 x Belt Clip
1 x Handbag
1 x Battery
1 x Intelligent Seat Type Charger
1 x Power Adaptor
1 x Operating Instrutions
1 x Headset
Baofeng DM-5R Buyer Beware
THIS RADIO IF IT ONLY SUPPORTS TIER 1 DMR CAN ONLY BE USED IN SIMPLEX MODE AND THUS WILL NOT BE USEFUL TO ACCESS DMR-MARC REPEATERS OR THE BRANDMEISTER REPEATER NETWORK
THEY WILL BE USEFUL TO OPERATE AS A FRS OR GMRS RADIO IN DIGITAL DMR MODE ON TIME SLOT ONE
THE BAOFENG SERIES OF RADIOS HAVE BEEN FAITHFUL RADIOS AT A GREAT PRICE POINT OVER THE PAST YEARS AND AN IDEAL GO-KIT, GLOVE BOX, FIRST RADIO, 7TH RADIO, OR YOUR ONLY RADIO
BUT UNTIL Fujian Nanan Baofeng Electronic Co. CAN CONFIRM IF IT SUPPORTS TIER 2 THE PURCHASER OF THIS RADIO MAY NOT BE HAPPY IF THEY PLAN TO USE IT FOR DMR-MARC OR BRANDMEISTER REPEATER USE
THE 16 CHANNEL SELECTOR IS MISSING ON THE RADIO AS WELL
andreu85
с окт 2007
Киев-UKKK
Дата: 19 Сен 2016 02:45:24 #
в любительских ДМР-ретрансляторах работать сможет? кто-нибудь может подсказать?
GIBBON
Минск
Дата: 19 Сен 2016 09:04:07 #
Выше ведь написано, что:
THIS RADIO IF IT ONLY SUPPORTS TIER 1 DMR, CAN ONLY BE USED IN SIMPLEX MODE AND THIS WILL NOT BE USEFUL TO ACCESS DMR-MARC REPEATERS OR THE BRANDMEISTER REPEATER NETWORK
blackhyu
с ноя 2013
Дата: 19 Сен 2016 12:17:40 #
Вроде только с 26 сентября начнутся продажи. Баофенг пока молчит на эту тему. кому с DMR ретрасляторами работать - то да, сложновато, а кому нужна защищенная цифровая радейка - очень даже гуд цена
Петров-Рабинович
с сен 2015
пока еще Земля
Дата: 19 Сен 2016 12:57:39 #
зачем дмр, если в репку не алёкнуть...
BOBEP
с ноя 2009
Минск
Дата: 19 Сен 2016 15:04:27 · Поправил: BOBEP (19 Сен 2016 16:12:05) #
С языка сорвали:), хотя в описание имеется Support DMR repeater function (DMR Tier 1).
И цена более чем адекватная для DMR. Я бы даже сказал "подозрительно" адекватная.
Подождём посмотрим, что это будет за "зверь".
koten
с мая 2014
Дата: 23 Сен 2016 14:45:11 #
update: Support DMR repeater function (DMR Tier I; support Tier II if upgraded with less than $10) - итого 79$
GoBliNuke
Offline5.2
с авг 2012
RadioAlert.ru
Дата: 26 Сен 2016 20:42:41 #
На всякий случай выложу ссылку, вдруг кто-то ещё не знает сайт старины Брика: http://www.brickolore.com/search/label/DM-5R
blackhyu
с ноя 2013
Дата: 27 Сен 2016 21:42:57 #
кто то уже заказал?
Забыл пароль и логин
Дата: 04 Окт 2016 16:32:16 #
кто то уже заказал?
Вроде бы 30 заказов сделано, хотя сейчас посмотрел - 27.
Появилось ПО http://tinyurl.com/hmfvhlw
и мануал http://www.radioddity.com/skin/frontend/base/default/download/DM-5R%20User%20Maunal.pdf
Sybereks
с июл 2014
Калининград
Дата: 05 Окт 2016 23:02:32 #
странно почему она через чепитеры не должна работать ведь все базовые настройки для репы вроде есть даже в мануале
Скиталец
Кавказ
Дата: 08 Окт 2016 12:11:35 · Поправил: Скиталец (08 Окт 2016 12:17:44) #
test
Скиталец
Кавказ
Дата: 08 Окт 2016 12:12:42 · Поправил: Скиталец (08 Окт 2016 12:20:03) #
Цена DM-5R действительно очень низкая.
Будет ли DMR директ (прямая связь между р.станциями) хорошо работать, это вопрос?
Скиталец
Кавказ
Дата: 08 Окт 2016 12:15:59 #
Через аналоговые репитеры она работает, это понятно.
А вот в DMR сети с TIER1 работать не сможет, Здесь действует лицензионная политика.
Tier I (unlicensed)
Tier II (licensed conventional)
Tier III (licensed trunked)
Предполагаю, что в прошивку дополнительные режимы Баофенг может легко добавить.
Hacker-CB
с ноя 2014
Дата: 09 Окт 2016 20:18:30 #
В среду лечу в Китай, наверно куплю потестить... В инете везде 69 баксов, но в Шеньжене на рынке наверно дешевле будет...
RN3ZF
Offline5.2
с дек 2004
Дата: 17 Окт 2016 14:44:08 #
Hacker-CB
Купили станцию?
Sanek200
с фев 2010
Дата: 13 Ноя 2016 23:18:32 #
интересно в транке она сможет работать?
GIBBON
Минск
Дата: 14 Ноя 2016 10:31:29 #
Не сможет.
Alex1
Offline4.9
с фев 2013
Ижевск
Дата: 17 Ноя 2016 22:36:24 #
На Али есть уже две версии: обычная и "плюс". Во второй, вроде бы есть поддержка ретрансляторов(?!).
Но у меня простой вопрос: если нет желания "свистеть" в репитер, то покупать первую версию?
То есть как простой декодер выходов ретрансляторов DMR, различных служб сгодится и первая Tier I станция?
deepaer0
с ноя 2015
Дата: 18 Ноя 2016 12:46:09 #
Alex1
Я тоже присматриваюсь к этой радейке, но вот тут http://forums.radioreference.com/budget-entry-level-transceivers/341568-so-my-dm-5r-came-today-2.html описывают опыт програмирования этой станции - и я лучше воздержусь от покупки этого баофенга.
Проще взять TYT / Retevis чуть дороже, но там уже есть модифицированная прошивка сканнер мод, будет ли такая же на этот баофенг - сомнительно.
xyz
с июл 2006
Дата: 11 Дек 2016 22:21:22 · Поправил: xyz (11 Дек 2016 22:28:42) #
Получил станцию, версия Baofeng DM-5R PLUS
Прошивка:
- по данным станции: 102016 (вероятно 20 октября 2016).
- по данным CPS (программы на компе) 2016-09-21
Третий день ковыряюсь с ней. Наконец удалось принять цифру, подробности тут: Как с помощью DMR радиостанции слушать эфир? - Страница 9
Настроить приём dmr на станции нельзя, только через CPS (как и ожидалось).
Станция полна глюков, но будем надеяться, что это поправят с новыми прошивками.
Проблемы:
- Не сохраняется шаг частоты, после выключения сбрасывается на 2,5 кгц.
- В канальном режиме при отображении частоты пропадает отображение канала справа.
- Сброс станции происходит не полностью!!! Пробовал режимы VFO, ALL.
- CPS безумно кривой, программистам надо вырвать руки, и поместить в более достойное место.
- Начнём с того, что в режиме программирования каналов невозможно ввести частоту!!! В поле ввода частоты отображается разделитель запятая, но ввести её нельзя, можно только точку! (наверняка это завязано на региональные настройки windows). Частоту можно ввести по частям, например "440 - ввод - стереть нули - 8625 - ввод". Можно написать частоту в блокноте (разделитель: запятая) скопировать частоту в буфер и вставить в нужное поле.
- Не все созданные каналы отображаются в рации!
- Сканирование идёт не по всем запрограммированным каналам.
В общем, продолжать можно долго. Продукт получился ОЧЕНЬ сырой, ждём обновлений ПО.
ТАНК
KN88
Дата: 12 Дек 2016 14:10:02 #
blackhyu
Чем обеспечивается защита?
xyz
с июл 2006
Дата: 12 Дек 2016 14:55:29 #
Есть 40 бит шифрование.
ТАНК
KN88
Дата: 12 Дек 2016 21:12:58 #
xyz
Какое?
GIBBON
Минск
Дата: 12 Дек 2016 22:04:01 #
Есть там некое шифрование, с виду, действительно 40-битное (те же 10 шестнадцатиричных символов), вот только сильно сомневаюсь, что оное будет совместимо с Мото или той же Хайтерой, лично пока не проверял...
xyz
с июл 2006
Дата: 13 Дек 2016 05:31:21 #
Кстати, с экономичностью у балалайки всё в порядке: вторые сутки (с перерывом на ночь) бухтит мчс, показометр батареи как был 3 палки, так и остался.
salafan
с апр 2015
Дата: 13 Дек 2016 17:45:21 #
Друзья, чем отличается Baofeng DM-5R от Baofeng DM-5R PLUS? Разница в цене более чем на 1000 руб.
Miller95
с фев 2016
Челябинск
Дата: 13 Дек 2016 21:43:50 #
А у мчс какая система кто знает? Мото или хайтера? Мне вот кажется они не станут пользоваться какой-нибудь иной системой. И думаю если dm-5r plus слышит их,то совместима. И еще видео на ютьюбе нашел где проверяли связь с мото и хайтерой и так же с 40бит шифр сработался с 60 битом.
Nevermore
с фев 2014
Озерск
Дата: 14 Дек 2016 00:09:06 #
А кабель программирование для неё свой нужен или от baofeng uv5r подойдёт ?
xyz
с июл 2006
Дата: 14 Дек 2016 01:58:47 #
