Notice: Undefined variable: w_logged_users in /var/www/srv20155/data/www/radioscanner.ru/lpd/whosonline.php on line 68 Warning: Invalid argument supplied for foreach() in /var/www/srv20155/data/www/radioscanner.ru/lpd/whosonline.php on line 68 Notice: Undefined variable: w_logged_users in /var/www/srv20155/data/www/radioscanner.ru/lpd/whosonline.php on line 72 Notice: Undefined index: w_logged_users in /var/www/srv20155/data/www/radioscanner.ru/lpd/whosonline.php on line 12 Двухдиапазонка Wouxun KG-UV - Страница 11
На сайте: гостей - 1,
 Страница:  ««  1  2  ...  9  10  11  12  13  ...  54  55  »»Поиск в теме
skynet_st
Ставрополь
Дата: 29 Июл 2009 13:53:18 #
5 - станция, как я понял, не имеет сертификатов
Сертификаты в наличии - 100%
Дата: 29 Июл 2009 15:53:58 · Поправил: Jafar #
ок. Проверил и нашел.
http://www.wouxun.su/images/certificate-3-bg.jpg
Начал действовать с 6 июля.
ursiaka
Одесса
Дата: 30 Июл 2009 00:33:41 #
На мой вопрос чем отличается версия KG-UVD1 от версии KG-UVD1P-? и можно ли с помощью кабеля и софта перешить KG-UVD1 в KG-UVD1P был получен вот такой ответ от производителя:
KG-UVD1P Upgrade Version
(1) This upgrade version aims at the setting on the master frequency, meanwhile changes the use method of the repeater.
Before upgrading, the transmitting frequency is along with the arrowhead points to after receiving.
After upgrading, in standby, the frequency that is pointed by the arrowhead is the master frequency. The frequency without displaying the arrowhead define as the vice frequency. Master frequency can be used for transmitting and receiving, meanwhile vice frequency is only for receiving.
Setting master and vice frequency: In standby, press [A/B] master frequency switch key to set. The frequency pointed by the arrowhead is master, the frequency without displaying arrowhead is vice.
When the vice frequency receives the carrier wave signal, the screen displays “S”. At this moment, press [PTT] key to transmit from the frequency pointed by the arrowhead (master frequency).
Upgrade version also solve the problem on the repeater in dual band. You only need to define the transferring transmission frequency or channel as master frequency, or define the transferring receiving frequency or channel as vice frequency. The setting is easily completed.
If transferring by channel mode, there is one more irrespective channel to be in standby at the same time.
Operation Method: Through keypad or programming software, please write the receiving and transmitting frequency into the same channel, and define this channel as master frequency. And the receiving and transmitting frequency on vice frequency can be set freely. Therefore, the transceiver not only can pass through the repeater, and also one more channel to be in standby.
(2) DCS/CTCSS Scanning Function Added on Upgrade Version
CTCSS and DCS can be scanned respectively.
Please see the detailed introduction on P38 of KG-UVD1P user’s manual from Quanzhou Wouxun Electronics Co. Ltd.
(3) Adding DTMF Encoding Function
DTMF encoding can be set by the optional function of the KG-UVD1P programming software from Quanzhou Wouxun Electronics Co. Ltd.
ЈЁ4Ј©Speedy Switch on Work Mode
Before upgrading, every time you want to switch the work mode, you have to enter MENU21 to switch. After upgrading, in standby, you just need to press [MENU]+ [TDR] keys to switch the frequency mode and channel mode.
Please see the detailed introduction on P28-29 of KG-UVD1P user’s manual from Quanzhou Wouxun Electronics Co. Ltd.
(5) The changes of use method in backlight can save battery power of the transceiver.
Before upgrading, if the backlight is set “ON”, it flickers no matter receiving, transmitting or operating keypad, which consumes the battery power very quickly. After upgrading, if the backlight is set ‘ON”, it will flicker only when you are operating keypad.
Please see the detailed introduction on P29 of KG-UVD1P user’s manual from Quanzhou Wouxun Electronics Co. Ltd.
ЈЁ6Ј©Adding High/Low Power Changeable on Transmission Mode
Pressing [TDR] key on transmission mode can change High/Low transmitting power.
This changing way is temporary. It will resume the previous setting after changing batterypack or restarting transceiver.
Please see the detailed introduction on P16 of KG-UVD1P user’s manual from Quanzhou Wouxun Electronics Co.Ltd.
ЈЁ7Ј©Adding Dealer Operation Mode
When you are in the open or computer and programming cable are not at hand, you can change the high/low power, CTCSS/DCS group, busy channel lockout, wide/narrow bandwidth and parameter on every channel through the dealer operation mode.
Operation Method:
Holding on [8] key and powering on the transceiver at the same time, then inputting password “268160”, the transceiver enters dealer operation mode.
When you are changing the above parameters on channels, please firstly call out the channel that will be changed, and set it as the master frequency through [A/B]. Then you can change the parameters of high/low power, CTCSS/DCS group, busy channel lockout, wide/narrow bandwidth .
SAVE & EXIT: Press [MENU]+ [A/B].
If I to have a cable and program and one can change KG-UVD1§Ь KG-UVP1 -? Sorry ,it can not.
вот такие пироги
Дата: 30 Июл 2009 09:09:44 · Поправил: Jafar #
Пока не будет достаточно информации в сети - станция не станет популярной, она скорее морально устареет.
Значит морально она уже устарела, даже не успев наделать шуму.
============много текста удалил, станция пока этого не заслуживает=========
Вообщем ажиотаж вокруг китайской двухдиапазонки был создан самими любителями задолго до ее появления (см форум), вовремя поддержан и пришло время на этом заработать.
maxmix
Дата: 30 Июл 2009 20:08:26 #
A если по русски,можно или нет? Я в аглицком не силен.Но судя по последней строке-нет не возможно.Или я чего-то не догоняю?
visor77
Одесса,
Дата: 30 Июл 2009 23:05:40 #
- If I to have a cable and program and one can change KG-UVD1§Ь KG-UVP1?
- Sorry, it can not.
- Если я имею кабель и программу, могу ли я превратить KG-UVD1 в KG-UVP1?
- Извините, нет.
skynet_st
Ставрополь
Дата: 31 Июл 2009 10:29:02 #
Это бы было ЧУДО !!!! :))))
UR6LAD
Харьков
Дата: 14 Авг 2009 11:21:25 · Поправил: UR6LAD #
если приделать к ней хорошую антенну, то много чего можно
http://irkham.ucoz.com/forum/9-23-240-16-1249837349
И наконец то первые связи через спутник АО-51,
В логе : BD8SY ; RN0QA ; UA4FKD ; 8J8WA ; UA9VIZ
visor77
Одесса,
Дата: 17 Авг 2009 15:54:06 #
Можно слушать два канала на одном бенде, но пока ещё не установил, одновременно или по очереди. В смысле два там приёмника или один...
Только поочередно. На борту один приемник, включает ту частоту, на которой раньше появился сигнал.
feri
Страсбург ФРАНЦИЯ
Дата: 18 Авг 2009 13:35:44 · Поправил: feri #
раскрытие на передачу
1. намите и удерживайте клавишу [6] и включите питание трансивера
2. на экране появятся два прочерка
3. введите код: 953708
4. вновь появятся два прочерка
5. введите последовательность: 138174400470
раскрытие на прием
1. намите и удерживайте клавишу [9] и включите питание трансивера
3. введите код: 051266
Сильно подозреваю, что последовательностью 138174400470 можно поиграться, т.к. это очень похоже на границы частот диапазонов.
Все правильно у меня удачно раскрывается и на прием и на передачу
122500122500 , ЗА ПРЕДЕЛЫ ЭТИХ ДИАПАЗОНОВ ВЫЛАЗИТЬ НЕ СОВЕТУЮ.
Станция раскрывается от 122 до 500 мГц
Авиа диапазон принимает нормуль , хоть и в ФМ , т.е приемник работает.
Дата: 18 Авг 2009 15:53:21 #
feri
Подтверждаю.
Всё раскрылось. Спасибо огромное!
Только по кнопке 6 диапазон приёма, а по кнопке 9 диапазон передачи.
Ruiz_Av
МО. г. Видное
Дата: 18 Авг 2009 16:29:19 #
Это данные про "Р" версию или про "обычную"? Как бы прошивки разные, на "Р" может и не работать...
feri
Страсбург ФРАНЦИЯ
Дата: 18 Авг 2009 16:37:19 #
У меня KG-UVD1.
US5EQQ
Днепропетровск
Дата: 18 Авг 2009 22:14:35 #
О завтра попробую !
Спасибо за инфо!
feri
Страсбург ФРАНЦИЯ
Дата: 18 Авг 2009 22:17:55 #
На 255,550 туповатая , да и на передачу включается на секунду, контрольный кутнтер показывает частоту 255,550 и потом происходит сброс передачи .
feri
Страсбург ФРАНЦИЯ
Дата: 18 Авг 2009 22:25:53 #
На передачу стабильно работает 122.000 - 198,995 и 400.000 - 500.000
На остальных частотах срабатывает на передачу правильно, но происходит сброс.
Titan
с июн 2008
Дата: 19 Авг 2009 00:45:56 #
У меня вышло на передачу 122.000-212.350, 400.000-500.000мгц
monk
Барнаул
Дата: 20 Авг 2009 10:38:52 #
На версии P не прокатывает(
cobak
Хабаровск
Дата: 20 Авг 2009 11:18:16 · Поправил: cobak #
Прикольная радива за 115 баков)) я бы взял... где можно такую заказать, кроме китая?
visor77
Одесса,
Дата: 20 Авг 2009 17:46:14 #
cobak, думаю, Вам Китай будет оптимальным местом заказа. Из Одессы отправлять - дороже выйдет.
cobak
Хабаровск
Дата: 21 Авг 2009 04:53:47 · Поправил: cobak #
visor77
Будете смеяться, но не всегда бывает дешевле, в Москве дешевле чем у нас продают, барыги.......
maxmix
Дата: 21 Авг 2009 14:16:14 #
Други!Где можно качнуть инструкцию на русском к 1P ? Или если есть у кого сбросте на мыло плиз
monk
Барнаул
Дата: 21 Авг 2009 16:04:22 #
Прислали мне прогу для изменения диапазона частот UVD1, попробуйте, мб сработает и на UVD1P. Сам проверить не могу, дата кабеля нет... http://ifolder.ru/13640360
Ruiz_Av
МО. г. Видное
Дата: 22 Авг 2009 00:47:02 · Поправил: Ruiz_Av #
monk, На версии P не прокатывает(
Я собстно и писал об этом. По этому просьба к обладателям данных аппаратов, писать после данных своих экспириментов, на каких станциях они проводились. С индексом "Р" или без такового. Информация действительно интерестная, но без указания модели, возможна путаница.
snegohod4ik
Дата: 23 Авг 2009 12:48:07 #
Никто все-таки точно сказать не может - получится ли раскрыть версию Р или нет? Сейчас стоит вопрос о том, что брать - Р или обычную.
Я тут порылся, судя по циферкам можно, но с испанским не в ладах, может кто переведет?
http://www.portalpmr.com/foro-pmr/wouxun-kg-uvd1p-t4449.htm
monk
Барнаул
Дата: 23 Авг 2009 13:22:26 #
Сслыка не работает( Народ, попробуйте программой, которую я выложил!
snegohod4ik
Дата: 23 Авг 2009 14:28:28 #
http://www.portalpmr.com/foro-pmr/wouxun-kg-uvd1p-t4449.html вот правильная ссылка
snegohod4ik
Дата: 23 Авг 2009 14:34:27 #
на сколько я понимаю речь там идет именно о Вашей софтинке и с помощью нее человек открыл станцию на 0-999
monk
Барнаул
Дата: 24 Авг 2009 17:51:34 #
Посоветуйте, пожалуйста, схему дата кабеля, я соберу - попробую зашить частоты в kg-uvd1p
snegohod4ik
Дата: 24 Авг 2009 18:54:15 #
Для Kenwood'a и Wouxun'а на сколько мне известно провод абсолютно одинаковый...
вот схема для кенвуда
http://www.cqham.ru/images/kpg-22.gif
